Wow, lots of questions! Let me know if I miss one, here goes.
The tapes don't last very long, at best 2 or 3 smaller knives. They are aluminum oxid and they feel like a very fiable type to me. Great for polishing but it breaks down fast. I think that after a fresh dress the diamond stones cut almost as fast as the polish tapes but won't quite polish as well as the second or third knives sharpend, after which they are pretty consistent. When
It sounds like Simple Green isn't a problem, but I don't know if it is any better than a little soap. I think the only thing a little soap would do is help keep the stones clean, but you will still need to clean them with some alchohol occasionaly.
I like regular stones for softer steel, but like the diamond stones for anything hard enough for them to really work well, say roughly 58 rc. I think the diamond leaves less of a burr when doing edge trailing passes, this is something I would like feedback on.
The softer the steel the lower the grit that works. We all have observed that while going through the grit progression the scratches start to get deeper at some point. The softer the steel the lower the grit it happens with. The difference between the 4000 and 6500 is tiny in the best circumstances, under the microscope. The 6500 needs good 60+ rc steel to work better than the 4000. If that is all you sharpen then you may want the 6500 instead of the 4000, you can go from the 2300 to either the 6500 or 9000, which is the finest I have found works on anything, so far only on ceramic.
EP is getting in some 240 grit aluminum oxide for dressing these stones. They dress the same way as any other stone, just much faster since the resin isn't that hard. Be real gentle dressing them, this is where all of the wear is for the 2300 and up, not in using them. How true this is on the 650 and 1100 is yet to be seen. Dress them until they look clean again and no longer. Dressing with wet loose abrasive on a flat plate leaves these stones performing best, significantly better than using 200-320 sandpaper wet, or anything else I have tried. The secret to getting the most out of the resin bond stones is dressing, it can completely change the way they work.
Thank you for your interest!
