I thought I would post this in it's own thread so that people not following the other could read it.
Hello all,
Let me straighten out some of the misinformation being spread about steels in use
by ourselves and most other factories.
1) Hitachi Metals is not ceasing to produce ATS-34. In fact, they are in the
process of trying to improve their manufacturing operations so that they mat
provide a cleaner melt and finer end product. ATS is not garbage and is one of the
best steels available.
2) We use 154CM because Crucible Steel approached us 2 1/2 years ago with the
proposition of producing 154CM in usable sizes (sheets) and wanted to know if knife
companies were still interested in their steel.
We consulted with Microtech who were already starting to use 154. They were
extremely pleased with Crucibles processes, delivery, and product. The steel had a
proven battle record for blades and I had used it almost 20 years earlier on my
custom blades.
154CM is the parent steel of ATS-34 and is U.S. made. We are extremely pleased
with 154CM and have never had any complaints about the performance of our
steel.
We produce tens of thousands knives per year and have well over one hundred
thousand out in the hands of users. Bear in mind that these really are hard use
customers and we are completely satisfied with the performance of 154CM.
It is heat treated per my specs and use a double temper and -120 cryogenic
treatment. This can be varified through our heat treater whose number I will gladly
provide to anyone who so desires.
3) Latrobe BG-42 is a good steel, even a great steel. The heat treating is not
exotic and any commercial heat treater can heat to specs required including the
-120 treatment which is the standard cryo figure.
Unfortunately, Latrobe Steel provides BG-42 for bearing applications and not
specifically for knifemaking applications. This is handled by their specialty steels
division. They produce the steel in bar stock and in small runs of such. Bar stock
will not work for major manufacturing processes. Most companies use lasers like
ours that require sheet stock material.
Yes, Latrobe will do a run for a certain quantity and dollar amount. It is not always
the price but the ongoing availability of raw material that is the determining factor
in choices made by manufacturers.
Our factory is set up on a just in time model and long lead times and guarantees of
only small quantities, prohibit the use of this steel.
The Latrobe company does not look at the knife industry as a large enough
customer to release mill time to address to address cutlery in the tonnage needed
to supply major manufacturers at this time.
Perhaps this will change in the near or distant future. Remember, they make this
steel for turbine bearings and almost all of their production goes to that application.
I hope this helps address and clarify some concerns that you all may have.
Sincerely,
Ernest Emerson
Emerson SpecWar Knives
Emerson Knives Inc.
Emersonknives.com
The #1 Hard Use Knives In The World
Hello all,
custom blades.
steel.
Sincerely,
Ernest Emerson
Emerson Knives Inc.
Emersonknives.com
