Body screws are tight. I can certainly take them out and measure them but it would be useful to know the standard size.
Both washers are there. I actually did disassemble and reassemble the knife when I received it. There was some chunky threadlocker in there and I get the impression the knife was not previously taken apart (which the previous owner confirmed). The knife is almost 5 years old.If you're going to order from the U.S. there are a few places to get washers.
They look like phosphor bronze washers. I don't know the thickness of the washers or the o.d. or i.d. but if you mic that you should be able to order what you need.
You may even bump up a few thousandths in thickness to fix your issue, if necessary but there are a few factors that come into play for that to work.
You most certainly checked this but maybe worth a mention....are both washers, in fact, actually present? Make sure someone didn't forget to put one back in.
You can get a selection of sizes and thicknesses of bronze washers at knifekits.com or usaknifemaker.com.
Man......just out of sheer curiosity, I've been googling washer size for the para 3 and NOBODY can list it......lol. There are lots of threads and same exact questions from many all over the web. But apparently there aren't any para 3 owners that also own a micrometer, dial caliper or even a machinist ruler.Body screws are tight. I can certainly take them out and measure them but it would be useful to know the standard size.
I saw the etsy store listing as well. They don't list the size either. I'm pretty confident that guy isn’t making or having someone else make custom washers for that knife.There's a vendor on Etsy that sells replacement Phosphorous Bronze washers for the Para 2 and Para 3 (the vendor indicates both knives use the same size).
I've never purchased them, so I cannot vouch for either the washers or the seller.
Trying to replace original washers with aftermarket ones can sometimes be difficult. Many knife makers have washers made specifically to fit their knives. And if the pivot is a metric measurement, the washers will be metric, and metric aftermarket washers are harder to find, if not impossible (depending on size). From what I've seen, generic aftermarket PB washers made for knives tend to be measured in fractions of inches (but there are some metrics out there). However, if the washers are .010 thick or more it's possible to file them, both inner and outer diameter, in order to produce a better fit.
But it looks like there are people out there producing direct replacement washers for a variety of knives.
Generally the washers I (and most of my custom maker friends) use are made with inside diameter for standard size pivot pins and are a few thousandths oversized. The outside diameter can vary widely and can be turned down.
I have phosphor bronze washers in .005", .010", .015" and .020" thicknesses for 1/8", 3/16" and 1/4" pivot pins.
I don't have first hand knowledge of a para 2 or 3 but it seems like, if the bushing is thicker than the blade, you would measure the bushing, find a washer that slips over it (maybe that's the issue...bushing diameter??) and get the appropriate diameter washer in appropriate thickness.
That is true.I don't know where that vendor gets his washers from, but everyone who sells aftermarket washers has to get them from somewhere (including vendors like USA Knifemaker, Knifekits, etc). There are businesses that will produces batches of custom PB washers. Some enterprising individual might decide to have some made if they think there is a market for them and they can make a profit. I've purchased several custom folder/switchblade parts over the years that were only available from the individual who sold them, because he paid to have batches of them made (pivots, sears, rocker arms, leaf springs, even blades).
As far as sizing washers, I replaced a set of worn-out plastic/nylon washers in an Al Mar SERE 2000 recently. 3/8th" OD was a very close match, but I had to enlarge the 3/16th" ID out to 5mm (the pivot size). 3/16th" ID was too small, and 1/4" ID would have been too big.
Good to know. Do you mean the dark ring or actually metal around the inside diameter?The lip here (created by wear) is what's keeping you from tightening the pivot further, either flipping the washers like I mentioned or carefully sanding off that lip should help.
The metal, there is a tiny step just inside the dark ring...that's the original thickness of the washers where it was hidden under the pivot bushing.Do you mean the dark ring or actually metal around the inside diameter?
I found a few posts similar to this. I think my problem is unique in that it is not possible for me to make my pivot tight enough to "seize" the action. Thank you for sharing your experience.Got pm2 recently with s45 on board, so recent release. It was drop shutty and all but would have play even with lock engaged. If tightened, it would seize and when i backout the screws a bit, it would start to have this play. Just couldn't dial things in.
That was just how it was before I got into it. After I did what I did, I tightened the screws all the way and it has no affect on the action.I found a few posts similar to this. I think my problem is unique in that it is not possible for me to make my pivot tight enough to "seize" the action. Thank you for sharing your experience.
Thanks for pointing that out. Sounds like it’s somewhat expected behaviour to have a tight pivot screw and drop shut action.That was just how it was before I got into it. After I did what I did, I tightened the screws all the way and it has no affect on the action.
