Please get the FIXED BLADE PRO HUNTER back on the assembly line, this is a fantastic looking knife, not sure why you'd discontinue it !
I agree 100% I need a pair I own 2 PH folders need a pair of PH fix blades !!!!
I agree with previous posts:
1. Would buy a Pro-Hunter Junior built to Pro-Hunter Magnum standards, including the flat grind and higher-grade steel. I bet this would be a good seller as it is the perfect size for everyday pocket carry.
2. Would buy a Pro-Hunter fixed blade if available (kicking myself for not getting one of the few New Graham had when I saw them become available).
- Matthew
a thinner small tek-lok. It doesn't need to be as tough as the current model. A little narrower too. Maybe do the same spacing vertically but only two columns of holes 1/2" apart. Minimal overlap beyond the screws as well.
Basically a tek-lok type item for smaller knives being carried in the civi world. On many of my little knives the tek-lok is overkill but I don't want to go to just a small loop or clip. The thickness of your clip would be good.
The only thing stopping me from buying a Ganyana Lite and a Pro Hunter Junior is the lack of tip down carry option.
Deeper carry, longer length "belt loop" attachment for your UCH IWB.
Which firearm do you carry in the UCH ?
Sent ya an e-mail, Thanks!
- Matthew
