Sorry to hear that.
Have you tried slicing paper or shaving along different parts of the edge - there might be a slight possibility that it could just be a section of the edge that is not sharp?
Do you have a magnifier or lower powered microscope to look at the edge?
There are some very good but cheap LED illuminated microscopes that do this well -
I recently bought all the cheapies I could find - and one in particular was pretty good at it, enough that I bought the slightly lower powered version so I have two of the same type.
groups shot of illuminated microscopes -
the 2 that were pretty good - 60x and 45x
both of these were cheap - and I mean cheap - less than $3 shipped
I think I prefer the 60x - although the 45x image quality is better - the 60x has the high magnification.
Before one thinks higher the better - the right most in the first group picture is a 60-100x zoom microscope - but its image quality is pretty poor - due to glare/flare in the lenses.
Important note: some of these magnifications bear no resemblance to reality.
eg: the 60x is higher mag than the 45x - which in turn is significantly higher mag than the magnifying glass (second from right) which was also listed as 45x.
The 60x of the good ones is no where near as high was the 60x on the zoom microscope, and not even as high as the 30x of the bottom microscope.
I understand magnification should be linear - ie: a 4x magnifier ought to make something look 4x bigger (linearly). Sometimes to boost/inflate specs some may claim area magnification which is the linear magnification squared - so that the same 4x linear magnifier could be advertised as a 16x magnifier
The good 60x, 45x and the magnifying glass show image the right way round so really ought to be classified as magnifying glasses - whereas the others the 60-100x zoom and the bottom 30x are true microscopes that show the image reversed (left/right and up/down reversed)
All except the bottom one are LED illuminated. I bought the bottom one because it was listed as LED - but it turned out to be regular (incandescent) light - when I complained the seller just refunded my money.
That bottom microscope is very similar to the Tasco 30x illuminated microscope I already have
marginally, this old Tasco illuminated microscope still has the best image quality to me.
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://UnknownVT.multiply.com/photos
