Anybody know where I can get a 1/4" countersink with 3/16" pilot? Need it for pivot screws on bolsters and handle slabs. I've used a 1/4" bit but it tends to grab the material and with mycarta it can realy screw up a scale.
i neeed to get one of them also
but till then i leave the piece clamped down and run the 3/16 then chuck up a 1/4 end mill and chase the hold to the depth i want
i do that for ll my corby bolts too
Will: You can order them from MSC. For Micarta, you can use a 1/4" reamer.
For bolsters, you can use a 1/4" end mill.
In both cases, clamp your work and use the 3/16" bit to line it up. Then, switch over to the 1/4" tool.
jlindustrial.com, mcmaster.com
I believe Harbor Freight also has them.
A little note: Micarta will eat a countersink faster than I can eat a Hershey's white chocolate hug (HMMMM)! So buy a few cheap ones.
Counter bore, or flat bottom counter sink, for use with pan head screws, I use an 82deg. reamer for flat head screws. I hadn't thought of pop's, I'll have to check on his site.
i think pops charges about 15 bucks or so for the counterbores.
sheffield has nice ones because they have interchangeable pilots, pops is nice but single task
they're made from 6 flute HSS reamers
