What can you get for a dollar?
I was really surprised to see a 7" Santoku at my local Dollar Tree -
How good can it be for a dollar?
How wrong could it be for a dollar?
I spent a little time trying to find one that seemed to have a narrow bevel - which usually means that the blade is thinner toward the edge
- that is through the plastic.
So I spent a buck....
Carefully opened the pack (tell you why later)
Tried the blade as is....
about as a sharp as a butter knife -
OK, slight exaggeration -
but it was not that sharp -
it certainly could not slice paper cleanly -
not only that, the time spent trying the find a narrower bevel - was basically wasted -
the "blade" - a laughable term - was pretty thick toward the edge -
I've seen camping knives with thinner edges!
OK what did I expect for a dollar....
I guess not much - but that's still a lot of metal for the money and it kind of looks nice.
So that's it?
That all I have to say?
No, wait there's is more....
(no I don't work on TV....
I took that thick slab that's laughingly called a "blade" -
as a challenge.
Could I possibly sharpen it enough so that it was no longer a mockery to the term "blade"?
Very fortunately I do have a Work Sharp (belt grinder) Knife Sharpener (link to review thread)
So I set to work on the "blade"
First the green P80 grit belt (the coarsest I have)
with the outdoor guide in place as a visual aid I held the blade vertically and set about grinding a 20deg convex bevel -
with (safety) glasses on, it took a long time to grind that convex bevel - despite the WorkSharp being very effective and efficient -
simply because the blade was thick toward the edge and the way it came the bevel was pretty obtuse (remember my butter knife reference?)
It could have gone quicker - since I was cussing and swearing....
which was a lot coarser than the P80 grit.....
I then used the red P220 medium grit belt and finished with the purple 6000 grit.
But I ws not quite satisfied because I still could feel a shoulder/discontinuity to the bevel - it is now a lot better than before -
but I still would like to make it better -
So I went beck to the coarsest green P80 grit belt and by eye halved the angle between holding the blade vertically and the belt surface and ran the blade pass a few times -
then I place the blade to as close to flat as I dared to the belt then passed the blade through a few times.
Just in case, I then used the red P220 medium grit belt with the blade held vertically for that 20deg convex bevel again -
and finished at 20deg with the ultra fine 6000 grit belt.
The resultant bevel was pretty wide -
the picture above on the knife out of the package was after the sharpening see how wide the bevel is?
Blade after sharpening -
Detail of bevel/edge:
After that pretty drastic sharpening - it finally has the right to be called a blade -
it will slice free hanging paper really well - being that it has heft - it seemed to out cut the CRKT Ken Onion Eros - my EDC -
but again I haven't touched up the Eros blade for some time now -
nevertheless that is pretty impressive.
It seems to cut well now and despite the thickness toward the edge - seems to cut through things well -
I think that is simply due to the convex edge.
I'll compare this to the Chefmate $6 Santoku (from Target) - please see: Another Santoku (cheap),
which does really well, rivaling my Victorinox/RH Forshner 8" Chef's knife (which is very highly regarded by many, including me)
all three side-by-side - later.
OK, why the careful removal from the package......?
if done right the package can be used as a blade guard/carrier......
it's free and any blade guard probably would cost more than the knife!
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://UnknownVT.multiply.com/photos
So that's it?
as a challenge.
Vincent
