1" vs 1/2" wide stones for fixed angle sharpener (Hapstone RS)
Hello,
looking at buying a set of sharpening stones for my Hapstone RS fixed angle sharpener. Is there a meaningful difference between 1" and 1/2" inch wide stones?
Which width do you guys recommend? I mostly sharpen kitchen knives, so I am leaning more towards 1" wide stones.
I prefer 1x6 inch for general sharpening and work great on kitchen knives. Gives a nice usable surface area and still narrow enough to see what I'm doing. 1/2 inch specifically for recurves (convex preferably, like venev gemini).
Wider stones make it easier to evenly grind & shape an edge without creating gouged or rutted areas along the edge, for a couple of reasons:
(1) I used to use a Lansky guided system with 1/2" wide hones. Their narrow width meant I needed to be more careful to avoid overgrinding a small portion of the edge, as the narrow hones make such errors a lot more visible and ugly. That alone is a good reason why you always want to go with a wider stone, versus a narrower one.
(2) Additionally, wider hones will be less prone to tipping and rocking from side-to-side as you sharpen. In simple terms, the wider stones have a more stable base of contact. That rocking instability of a narrower hone will cause the edges/corners of the hone to gouge your blade's edge bevels - and that's really ugly when it happens. This was another thing I noticed in using those narrow Lansky hones - they were much more prone to tipping to the corners.
There'll also be some small advantage due to the larger surface area of a wider hone, assuming length is the same. The point of contact between knife edge and the hone will move across the larger diagonal (corner-to-corner) dimension of the wider hone, meaning you're getting a little more abrasive contact on each pass. The difference in this is more obvious when going to something much larger, like a large bench stone at 8" x 2" or larger, where you'll see a dramatic increase in grinding speed to get the job done.
That is a good point with the narrow width overgrinding and it really would take quite a bit longer to sharpen kitchen knives. I will be getting the 1" stones then, they seem to be the standard anyway.
The standard is 1" wide, but the 1/2" are useful for blades with recurves or hooked tips
Hi, thanks for your question, I recommend you stick to the 1x6" stone form factor, especially for kitchen knives. You will be able to remove metal evenly and control the sharpening process better. 1/2" stones are good for curved knives or very small knives.
Mario
Hapstone !
