11” Dagger in 52100, Koa, Damascus…
This knife is a culmination of several ideas I’ve had over the past two years- some of which I’ve tried and failed at in that time. I’m pleased that through that practice I learned enough to pull it off this time.
The blade has an 8” hollow grind and is slightly leaf shaped, at 11” long from point to bolster. It’s forged from a 52100 bearing and hand sanded to 1500 grit. Overall length is 16.5” and width at quillions is 5”.
The bolster is of course integral, and has been drilled and tapped through to accept the quillions. It’s hand sanded to 600 grit.
The quillions are made of twist Damascus, also by me, and were lathe turned to shape and threaded on the ends. They were hot bent to final shape in place, so as to index correctly when tightened.
The handle is natural curly Koa wood from Maui. It’s nice and chatoyant! The front of the handle is inlet to accept the bolster.
The finial is the same material as the quillions, and was carved and filed to shape.
The finial nut was turned from 300 series stainless, as is the take-down tool- the knife can be completely disassembled.
You may notice that this dagger does not feature a maker’s mark- there was no place on the piece where I thought it was appropriate. I'm working on a torch mark that will fit in small places on a piece like this.
Enough yakking, here's pics! Hope you all enjoy looking. Opinions solicited.
I like it very much. Since it is a take-down design couldn't you put your touch mark on the tang?
Very nice Salem. Something different and I like it a lot. I agree, put your mark on the tang. Great job on a difficult piece.
Brion
Super cool Salem! There's a whole lot of cool factors going off on this one. That's a double difficult blade--- dagger and an integral... but you nailed it. :cool:
Thanks for sharing Salem! :)
very nice looking knife. great comments from Nick who can do great daggers as I can attest from one of his I have.
I had never been a dagger person....until NOW!! The intricate work, attention to detail and creativity in this one is readily apparent.....sweet!!
Wow that is very impressive!!! Really like the guard and how it is attached. Also the grinds are very impressive!
Sean
I love everything about the lines and shape of the blade, excellent work. The take down handle is another very nice feature. Great work.
Well executed and innovative! I enjoy something different comin' down the pike. Great knife!!
