- Mar 20, 2016
That would be nice. I guess i never looked at a brown dap sheath from you all, i would have gone with the black instead. Pictures of the color options might be a good idea. It’s ok though. I’ll try and darken it up with some mink oil.Yep, had a chat with the team about the colour and they've confirmed that it's the same brown leather we've been using the whole time. I have not beena fan of it historically- potentially at some point in the next year we can get an order in direct with the factory and arrange a brown that's closer to the western leather![]()
It is the actual point. I should have clarified also that it is the top point (the ine on the same side as the spine of the blade. I believe i am using a hammer grip but will take a look to confirm in a bit.Glad you're liking them! That's the right way of holding it- is it the actual point of the flare biting into your hand or just the ridge that leads up to it? Are you holding it in a tight perpendicular hammer grip? Or an angled grip?
Not really. I wear a size medium glove and most 4 inch handles i can get a full 4 finger grip.Based on this info then your hand could be a bit big for it yeah. Do you have particularly meaty palms?
In use try to hold it pinched between index and thumb like youre making an "OK" sign. When you chop you are kind of squeezing with your pinky and ring finger to accelerate the rotation of the blade into a snap cut. There shouldn't be a need to death grip it though- the flare should act as passive retention and keep the blade in your hand with only gentle pressure
