12 inch Ang Khola
Rusty
Moderator
Moderator
Am finally getting around to the second of three toys I brought home Thursday. ( The first was the 30" Sirupati I commented on in another thread. )
I haven't done anything yet with the 12" AK. Reason for that is the scabbard shrank to smaller than the blade width. I literally could not work it out of the scabbard without slicing thru the top 2/3rd to 3/4th inch of leather above the frog. Took a knife and file to the top inside of the scabbard next to the spine and smoothed it out. Explored every other thing I could think of and kept coming back to the conclusion the blade was just plain wider than the throat of the scabbard. Gave up and filed the edge down to make the blade a couple 16ths narrower. Now I have it taken down and it will go in without cutting the scabbard. But putting it in and removing the blade forces the already sliced leather and wood apart because it's too thick at the edge, and I haven't beveled it down yet.
Of course the widest part is the meatiest and also the most hardened part. The file wants to slip and slide over it rather than cut into the metal. This is the forte of the tungsten carbide V sharpeners that I'm sure a lot of knife people feel are an abomination. No, they won't put a good edge on a knife. Yes, a few LIGHT strokes will bring a previously sharp edge back to usability. But for me the one thing they do without peer is to hog metal off fast and shape it to where an edge can be worked with other tools. That's what I'm doing now.
In a way though, it's what the yuppies would call "quality time" with the baby AK. I'm getting to run my hands over every fraction of an inch of it without having to worry about getting sliced up.
The 12" AK is still very much an AK in the way a 12" Sirupati is still very much a Sirupati. The difference between the two 12"ers is about the same as the difference between 15" AK and Sirupati. The babies are just as much AK or Sirupati as the bigger ones. I just haven't figured out whether they are khukuris or not. I guess if you could call the Graf Spee a pocket battleship, you could call the babies pocket khukuris. I see a 15" or larger khuk as a "service" khuk the way a 4" K,L, or N frame S&W or 4" Police Positive, Official Police, or I frame Trooper or Python are open carry/service revolvers, and the 2 or 2 1/2" versions on the same frame are undercover/snubbie revolvers.
So bottom line is that it may be the littlest AK, but it's still an AK. Now I'll sign off and go back to fondling it.
That has too be a cute little khukuri!
What's the thickness across the spine Bro? I have been curious about one of these little ones for some time now.
>>>>---¥vsa---->®
The hardy adventurer just drank from a stream he thought was pure glacier fed water not knowing that upstream was being used by a herd of yaks as a giant bidet.
I said he was hardy, not smart.:-)
Khukuri FAQ
Just checked: in front of and right behind the AK fuller at the top of the spine, 7/16ths. At thickest part of spine, 15/32 by my eyeball and tape.
Yvsa -- I have a 12"er AK also. Nice knife but just a little to small for heavier work. I did chop some limbs off a maple tree that were about 3" around with no problem. The only thing is the handle hurts my hand a bit being smaller in size. Not a bad defence weapon though. Would be a handy blade for other tasks.
I, too have a 12" AK. Rusty is right, it is the "pocket battleship" of knives. I have the same trouble as Rusty with the sheath. If I can ever find a properly thick piece of leather, I think I will make a front-break scabbard for this puppy. My old-model Cold Steel LTC (I won't call it a khukuri) uses such an arrangement in Cordura instead of leather, and it allows for a fast draw. Only disadvantage is that reseathing must be done carefully so as not to cut the keeper strap.
I used to be fairly good at simple leather crafts...I believe this can be done.
--Mike L.
Real men ride Moto Guzzis!
Rusty.
... the widest part is the meatiest and also the most hardened part. The file wants to slip and slide over it rather than cut into the metal ...
I faced the same problem - anyhow, I made a finding ... cut it with a honing stone - it works better than file for the hardened part! I guess stone vs metal is better than metal vs metal ... any comments?
NEPAL HO!
[This message has been edited by mohd (edited 04-24-2000).]
Mohd:
Try to find the DMT double diamond hones.
The black and blue are the 2 coarsest and the red and green the finest.
Use the black for serious metal removal and the green for a very fine edge with the other 2 being for the middle work. I don't have a back one as yet, but that will be one of my next non-knife purchases.
They make the double sided hones in bench size now.
I imagine the 10" long size would be awesome in sharpening anythng.
On a world note, I just bought some Dowel Rods from the local Walmart and discovered when I got them home that they were made in Malaysia.
They are of a very hard white wood.
A little piece of Malaya will be out on the Indin Dance floor before long.
>>>>---¥vsa---->®
Khukuri FAQ
