- Jun 24, 2012
Here's a work in progress of a flipper folder that a customer recently placed with me, and it's my most ambitious design yet.
It has a total of 12 inlays!
Here's where I'm at so far...
Blade rough cut, between liners...no filler bar yet.
Lock cut into liner, milled out the pocket in the back to lighten up the spring tension.
Filler bar is made up of 3 pieces...the 2 end pieces are Titanium...
Blade is beveled...This is 320 layers of "Reverse" San Mai Damascus.
Outer layer is 52100 with a heavy layer of Nickel between it and the Twist Damascus core steel.
Now for the fun part! The sides are "Marbled" Carbon Fiber with Ladder pattern "Moku-Ti" (sourced from Chad Nichols).
The pocket clip side is shown in the top piece, and you notice the rear Moku-Ti inlay is shorter and more rounded...that's to accommodate the 3-D pocket clip...
Here's the pocket clip. Same ladder pattern Moku-Ti, milled away at the base to make it 3-D.
The holes line up perfectly with the pockets below that are milled into the rear Moku-Ti inlay
Here's the 3rd piece of the back bar.
It's a 1/8" rod I turned down to fit into reamed holes in the 2 pieces of Titanium.
It's made of the same ladder Moku-Ti as everything else so it should be pretty cool looking when it's all colored up.
You will also notice the steel washers around the pivot joint...that's to help prevent the bearings from wearing a groove in the Titanium liners over time and creating side-to-side blade wiggle.
Here's the Marbled Carbon Fiber inlays in the rear Moku-Ti inlay sections.
They are 1-72 threads and the screws are flat heads that are set into the carbon fiber, holding the Moku-Ti in place.
Each one had to be cut out, glued to a round rod, ground to shape, hand sanded for final fitting, then put in the hole, drilled and tapped.
They are about 0.060" thick, and there's 8 of them, so to say it was tedious is an under-statement!
I will post more as I get further along on the knife, but in the mean time, please let me know your thoughts & opinions.
I accept any and all feedback, positive or negative.
Thanks for looking.
Thanks for looking.
