I have a 20" grinder being made for me right now. I wanted to go minimum hollow / maximum wheel using standard belts. I have only been flat grinding so far, but can see some advantages in a shallow hollow grind. Plus I look forward to grinding with a wheel instead of on a platen, heat build up and belt life should be a little better..
What advantages do you see?
after using the 4 foot platen i really feel the need for a 36-40 inch wheel in the shop i just dont have the time or space to put one yet
look for your self .........this is Nakiri knife i work on , 2 inch wide and 3mm on spine , hollow only one side on 17 inch wheel .......What advantages do you see?
