With those steels the extent of the damage I experienced was dulling and occasionally a tiny chip here and there, so I was not prepared for the behavior of ATS 34 on what I consider to be light tasks (cutting plastic ties, cardboard, sharpening pencils, clamshell packaging).
Both the Terzuola and the Elishewitz have minor rolls running down the length of the blade as a result of a few weeks of infrequent use. While all three knives are now dull, the Emerson's edge has remained free of rolls.
The ATS-34 I have in my CRKT Apache cuts stuff up just fine :thumbup:
production knives with blades of harder, tougher steels like S90-V and Elmax
My Camillus folder was advertised as ATS-34 while the blade is marked 154CM !
Harder and tougher can vary with production and heat treat techniques making any one of knives in steels ATS 34, 154cm, S90V, Elmax harder, tougher , or whatever. Do you mean higher abrasive wear resistance instead of harder? I'm confused by this.
mete stated:
I have an EDC the same. Box states ATS 34 yet the blade is marked 154cm. I used to have a whole set. D2, 154cm, 420HC, Gold Ti Nitride fancied up version in Talonite, and lastly a taiwan produced one in Aus8. I don't recall selling most of them including the Talonite but it went missing over the years along with some other nice knives. I may never figure that one out.
joe
I don't see what I have to gain from sharing made-up, incorrect experiences. It's not out of disrespect to the makers, there is a reason that I seeked out and bought their knives. In addition, I specifically chose to evaluate three custom knives by these makers because I trust that they know what they are doing when it comes to heat treat and grinding without affecting that heat treat.
Why you infer disrespect in every post I make and bully me across multiple threads is beyond me.
I in no way "seek" anything of yours or about you. I simply read many threads, comment on some that involve my interest or knowledge. As stated I have collected knives 45 years, own Thousands. I have blades in so many different steels, I would be amazed if The latest and greatest is not within my collection, steel wise. Those on site who have seen my collection or have traded with me know 3 things about my knife selection process. 1. Steel type, 2. Function of knife, 3. Scale material. Hype, Price, brand never come into play. Ats -34 IMO, notice my opinion, based on 45 years of daily use, is ATS-34. I owe all the knives you pictured and own multiple knives from those designers, none of which ever "rolled" or failed in any manner. IMO, and this is a discussion, Emerson makes no better knife than the others shown. As fact the other 2 knives are of excellent quality. What I do question is your knowledge of steel and your review of what you say you found. As a "reading" member, your reviews and opinions surface a lot here and in GBU, So I either see you reviewing or giving advise. I simply disagree with any findings you have regarding Ats-34 as ALL the MFG. I listed and the 3 you showed chose that steel to make knives with. I would weigh their knowledge against any member here. When you appear in forum, claiming you have discovered flaws hidden within a product used industry wide and tested by millions of people, it draws attention from me.It is not you I question, it is the groundbreaking research , and non ending advise you offer that as I stated amazes me. Clearly your knowledge is unsurpassed. You have highlighted a "problem" the greatest knife makers, engineers and companies did not locate. That is why I said I was amazed. Please accept my compliment, amazing work.
Thanks - since that's a knife also from the 90s it should be somewhat comparable. What have you been using yours for and how long is it usually between sharpenings?
That's rich, your unique Elishewitz treeshaker also owns. I think that shows you where he's really coming from, "Ignoreland"![]()
What Terzuola do you have?
ATS-34 is a good steel. I have old and new knives with it and have had no problems. Benchmades 154CM is essentially the same steel and they still use it. I have a new Benchmade Pardue with 154CM and it's an excellent steel with a good long holding edge.
I've not had a "problem" with it rolling, your rolling probably just means the edge angle was not right for your application, but the heat treat didn't get you to the point of chipping.
Recently I have been using these three knives for a variety of light tasks.
All three were produced in the mid to late 1990s. All three use ATS 34 steel.
