Generally Jerry's heat treats emphasize maleability at high hardness, or as close as a steel can get to that. With his treatment of D2 a rat hunter was able to sustain usability under a lot of hammer blows, both to the edge and spine. The edge dented and mashed and the spine only took one major chip/breakaway. For being 58rc thats pretty decent for d2. I don't know how he does this, but part of it is extensive use of cryogenics to relieve as much stress from the blade as possible.
So if you want the highest possible wear resistance, you may have to look elsewhere with 154cm, somewhere that goes for 62rc+. Jerry's will be the most likely to avoid damage at any given rockwell, but it may not go to the extremes you may be looking for. The one instance so far where that may not be the case is with the scrap yard sr101 scrapivore at 62-64rc.
