154cm?
Hey does a 154cm blade bend easily? Like if you were to drop it on a hard surface? Dropped a knife but I can't tell if it's slightly bent or not. It's hard to tell.. Thanks
I wouldn't expect the blade to bend. If it landed on the edge, the edge might be deformed or chipped.
I'm sure it bent at least .54nm.
Probably a safe bet.
If the knife is not important enough to avoid dropping it on a hard surface, and you can not tell if it is bent, it does not matter.
Hmmm...the question you should be asking yourself is, "after it bent .54 nm upon impact, did it bend back to where it started?" XD
