- Mar 5, 1999
Here's a very nice 18 inch, 28 ounce AK by Durba. This knife suffered a little tip damage (minor as you can see in the pix) that will take maybe 15 minutes to work out. The tip may be a little softer than usual so if you do heavy chopping with this knife don't do it with the tip -- use the belly where the blade is hard.
The knife is horn handle but has very good karda and chakma with wood handle. Good scabbard and frog.
Take this knife fo $95, do 15 minutes work on the tip, and save yourself $50. If you don't try to chop with the tip this knife should last 100 years.
