- Mar 4, 2023
This bar you have is laminated steel, correct? with mild steel claddingH HSC ///
Hello,
I noticed your thread here below and am a little confused about SHIROGAMI #1 and
am trying to find answers online despite most Westerners have not tried Japanese steels.
I have 2 questions below and hope you can answer them.
It seems in the thread below that you temper the steel at 356°F for only a short time.
laminated Hitachi White and Blue Steel Heat Treat Process
To help with the recent HT sticky, Im offering what I have learned and use myself relative to laminated Hitachi steel. I'll outline and detail the process as taught to me over about 9 days with Murray Carter over 2 separate visits. Carters book on bladesmithing is also a reference...www.bladeforums.com
I was under the impression that most steels were tempered for like 2 hours. I have watched many videos
of Japanese Swordsmiths temper a katana right after quenching at a reduced temp and quench again a
few minutes later.
Question #1:
Is this Shirogami #1 meant to be heat treated the same as Tamagahane once it's a blade?
Question #2:
I noticed a White Paper Steel tempering chart in fig.2 of the following pdf and was wondering
if tempering at 300°C would result in a 60 RC hardness. If so, would I be able to temper in
minutes vs a 2 hour tempering cycle?
Note: My SHIROGAMI #1 bar is in the 1st post of this thread.
Thank You,
Cheers
Interesting. I wasn’t aware Takefu offered a monosteel bar like that. In fact judging from the looks of your picture I’d be willing to bet it’s laminated. I can tell from the surface texture of the barHello,
The bar is solid and not San Mai clad.
The plan is to make 2 blades with 1 being more than 3 times longer than the shorter of of the 2.
I'll do my initial testing with the shorter one and be sure to post what happens here when I do.
I have other types of steel like O1, 1084, W2, 26C3, Sheffcut and 1045 to play with before I try
anything with this Japanese steel.
Thanks for your time.
Cheers
