- Jun 4, 2010
Another quick (10 minute) WB video. Wanted to make one showing the use of reclaimed mud from a waterstone - some technique on a JWS and restating some benefits peculiar to the WB. Pretty much any grit of appropriate abrasive can be used on the WB with increased utility compared to other methods. In the case of most Japanese waterstones you're already creating mud that can be quite useful. When lapping a dished JWS flat is another perfect time to make a few stropping sheets - each will last for multiple sessions. One can also use this method by wrapping the paper around a regular stone or other hard surface and works well, but will not get the same effect.
The slice was taken off my stone with a diamond grit sawsall blade and one of the handle adapters for using sawsall blades manually. Just flush with water often and it will cut right through. Have done all my King stones and Norton waterstones very easily, and even cut an inexpensive 8" AlumOx combination stone lengthwise to make a multi-grit canoe stone.
Thanks for watching!
[video=youtube_share;RXr-FPME-jc]http://youtu.be/RXr-FPME-jc[/video]
