I just got my BAS Villager 15" Kukri from HI. I was able to try it out outstide on several types of wood and brush.
I was actually impressed with it. I didn't expect it to preform as well as it did because it is only a 15" Kukri and not a large heavy chopper like some I have seen. I am no expert in the use of these so I know that if I were more skilled with this tool, my results would have been better.
It cut medium sized branches best out of everything I tried. This knife seems best suited to chopping small firewood and braches. It can clear brush but a machete would be a better option if that was the main use. It can chop thick wood and trees but an ax would be much better at that as well. It seems to have a niche and that would be what I would call the "camp knife" role.
It does have some advantages over both the ax and the machete. It can be used when there is not enough room to swing a long machete and it can be used with one hand unlike an ax.
I didn't like how the bottom part of the handle dug into my hand. The brass plate is a little sharp there and my hand is a little too beefy I guess.
It is hard to compare a Kukri to a machete or an ax so I won't try. I also got a British Golock for X-mas and got to try that out as well. It is about the same size and weight as the Kukri I got so I think it is a much better comparison. The fact is, there is no comparison. The British Golock was not even in the same class as the Kukri. The Kukri did everything better. The Golock seemed to have a more comfy handle until I used it for a while. It translated more shock to the hand than the Kukri did and twisted in the hand more as well. The Golock felt like I was bashing a log with an unsharpened truck spring next to the Kukri. If you are considering the British Golock, don't waste your money. The Golock did not have an even grind on the edge and it wasn't really convex either. It was a sorry excuse for an edge and anyone here would have to rework the edge before they considered it ready for use. The Kukri came ready to go.
I have a lot to learn on the Kukri but it is worth spending the time doing it because I think it is a good tool. No one tool will be best at everything so as long as it can fill a role, that is good enough. It hasn't replaced my U.S. army issue machete for any serious uses as of yet but it may well find a place if I put the effort into using it that I think it deserves. I knew right away that the British Golock was a total waste of time. I have a lot of experience using the machete and axes so even though the Kukri is very different, there are some similarities as well. The more I think of it the more it seems like what would happen if you mated a machete to an ax would be a Kukri. Jack of all trades, master of none or niche tool? The jury is still out but it has at least proven to be a real tool with real uses and not just another gimmick.
I can see how you guys get addicted to these Kukris. Even though I was not blown away by the 15" BAS, all I can think about is maybe getting a Ganga Ram for heavy chopping and a Kobra or similar slim and light Kukri for brush and light veg. It would be neat to be able to try out every Kukri, machete and camp knife side by side and see what works and what doesn't. Until then, I will just try one at a time. I already found something that works for me (machete) but it is fun trying new things as well. I have my old stand by but I like to experiment as well.
