1st knife is almost done. Pics
So I learned that getting a good picture of a knife is not easy. Don't have a real great camera so they are what they are. Love it or hate it don't be shy about saying it, won't hurt my feelings any.
It does have some flaws I know. The handle has a crack in it and the handle is off center a little. Tried to forge weld it together and lost my center in doing so. The crack is from my own lack of thought when I put in it a vice to shape the end. I wanted a hard handle but made it a little to hard, put it in the vise and I heard it crack, as you can imagine I said about every foul word I know. This knife is 100% Damascus.
It is a little heavy in the handle,a nickel and 2 dimes on the tip and it will balance on the finger guard so it is not that far off but off none the less. I should have milled out a little more of the inside of the handle but too late now. I put a ton of time into it and learned A LOT.
I still have some light sanding and clean up to do on it but it is close to done. Still need to get the final cutting edge on it also. Killed 2 diamond sharpeners on it, once I do get the thing sharp it should hold and edge for about forever.
Can really see the crack in this one...
Tape measure is still MIA so here it is next to a pack of wides and on a sheet of printer paper to give you an ideal on its size.
Very interesting! I have neveer seen one in that style! I like it!
Steve
Potomac Forge
IN GOD WE TRUST
Use some leather in the vice next time. and a good temper on the handle would have helped. For a first knife it is good. on your next one you might make your blade a bit thiner as it looks a bit thick to me. and some wood on the handle would be good mix things up a bit. the hard bart is done getting that first one out of the way. take what you learned from this and make your next one better. enjoy the ride.
