not2sharp
Platinum Member
- Jun 29, 1999
Lot Nr.42
A garniture of five Iberian weapons
late Hallstatt period, early Iron Age, 6th to 4th centuries B.C.
Consisting of: (1) A forged short-sword, also called Front¢n dagger, with slightly flared, double-edged blade with several fullers, the completely preserved quillons or cross-guard and the mushroom-shaped pommel with several projections riveted onto the blade tang: L 43 cm = 16.9 in. (2) Its sheath, riveted at several points, with a flat oval locket band and three partly still movable carrying rings. L 34.5 cm = 15.6 in. (3) A pertinent knife to be lodged, as were sometimes also spear and lance points, in a bulge provided for it in the sheath, with traces of silver damascening on the lower grip sheathing. L 19 cm = 7.48 in. (4) A pertinent lance with a short centrally ridged point, a stepped shaft, and a long hollow facetted socket with two holes for nailing it to the staff. L 26.5 cm = 10.4 in. (5) A pertinent lance shaft with two holes for affixing to staff. L 14.3 cm = 5.6 in. Excavated, well-preserved, well-restored pieces with an attractive surface patina. Compare a dagger blade acquired in 1989 by the Römisch-Germanisches Zentralmuseum in Mainz, published in the museum Jahrbuch No.36 (1989), Part 2, p.777, Fig. 66/1.
Here is the link to the catalog:
http://www.hermann-historica.de/auk...emgroup_1_GB&start=1&dif=10&db=kat44_1_GB.txt
