#2 finished.........
Dawkind
Platinum Member
View
Here's some more....... http://albums.photopoint.com/j/AlbumIndex?u=667533&a=9677925
Wow, that finished up nicely.
The blade looks great.
But, I'm a bit concerned about the top skeleton hole. That's the fatal flaw in Bear's handles. The material gets to thin and to weak near that top hole and the handle eventually breaks. Benchmade addresses the problem by making each hole a successively smaller diameter. But, They learned that by making a lot of balisongs.
This one really looks nice.
BTW, you might throw a standard ruler into the pictures occationally to give folks a sense of size.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
What, no latch??
LOL........ sorry, I couldn't resist.
Sweet! But Chucks right about that top hole. There's just not enough material left in that crucial area to withstand the pressure of manipulation.
Other than that, you're kickin' serious butt dude. Keep it up!
Clay
www.balisongxtreme.com
Because......
getting 'em open
is half the fun!
I'm addressing that flaw in the one I started last week. I'm modifying my jig so the taper won't be so accute. I thought of putting bolsters on it to strengthen the handles and still could. The new one will have handles of 303 stainless with micarta inserts; haven't deceided what blade style to plagiarize this time.............maybe a Mariner or how about a Reverse Utility???
By the way Clay, the next one will have a latch; I'm also going to use 5/32" blade stock to give me more 'wall' thickness and greater strength since the handle stock is 3/8"x3/4" instead of the 1/2" square stock I can't seem to find...........
[This message has been edited by Dawkind (edited 11-07-2000).]
Dawkind, I like the deep taper, why don't you just decrease the size of the holes by 1/32" or so, as you go up the handle. That should leave enough material at the top.
BTW, what do you use for the pins?
I really like the insert handles more than I do the skeletonized so this will probably be the only one like this. If I would make another, I'd take that advice. Bali-Song USA, according to Les' patent, started with 5/8" square stock that ended up tapering from 5/16" at the handle pin to 1/2" at the latch end, but the width remained at 1/2" the length of the handle. The handle was then turned/ground so that the handle was circular for 'manuverability'. My next one should be the nicest so far. The pins are from Koval Knife Supply http://www.kmg.org/kovalknives/ They're like $3.00 per set.
That is really awesome looking Dawkind!
Very beautiful!!
Keep up the good work.
Cameron
"Look deep, deep inside and you will find a place of anger, vengeance, and brutality. Go there. It is your last hope to conquer the truly wicked."
A few of my balisongs
My Photopoint album
Excellent piece. I agree with ChungSan - your next bali should be a tanto with micarta inserts, or maybe a kris!
a kriss.. woooh somethign to see
keep it up Dawkind.. not only is your collection awesome your skills are breathtakign too.
<A HREF="http://www.contrib.andrew.cmu.edu/~soo/balisong/balisong.html" TARGET=_blank>http://www.contrib.andrew.cmu.edu/~soo/balisong/balisong.html
</A> If you play with love you will be heartbroken; if you play with knives you will [bleed]
Keep this up kiddo and we will soon be visiting the "Dawkind-Song" Forum!
Sweet piece...again!
Regards,
Sabo 29
"Catch you on the flip side"!
