- Oct 3, 1998
Hi, I've got 2 questions(Actually, there are several questions, but in 2 catagories) I need to ask.
One is about heat treating. I've heard a handful of times that doing more than one quench(Bring the knife up to its critical temp. then cooling it down by brine, oil, air etc.) will bring grain size down. And make the knife tougher. My questions about this is, 1. Does it only work for simple carbon steels? I've heard of doing this for 52100 and O1, but I also think I heard at Blade that this will improve 440C also. and 2. Is each quench after the first done the exact same? Do you just wait until it is room temp then start heating it up again, or do you let it sit for a while. Do you use a less critical quenching fluid because there is already lots of stress in the knife?
And my second question is about heat build up while you are grinding steels. Which steels are affected my this? Most high-end stainless steels are supposedly ruined if you haet them up too much while grinding. I'm wondering if that applies to A2, D2 and 440C.
Thanks
Sincerely,
Adam
Self improvement is a hobby of mine
Thanks
Sincerely,
Adam
