- Sep 29, 2015
I’ve been working on these two blades on and off for almost a year now. I finally got them to the exact finish I’ve been trying to achieve. I have some curly maple scales with white G-10 liners I’m getting ready to fit to these blades. As soon as they’re done I’ll be sure to post pictures here.
Pictures: https://imgur.com/a/GmKTI83
This was my first time working with white steel and it was A LOT of fun fun getting to see the structure of these blades, and how they polish/etch compared to other steels I’m used to working with. I mostly work with Aldo’s 1075, focusing on hamons. The steel has a very plain look to its structure when its etched and polished, mostly turning a cloudy in the hardened area and that’s it.
But with white steel #2 when it’s polished and etched the structure of the steel starts to stand out. It has a swirling/waving/fuzzy grain structure. At first I assumed I had over heated the steel causing grain growth. But I noticed that when other people bring white steel (and blue steel to a greater degree) to a high finish it has this same effect. I would guess that this is from the iron sand Hitachi uses when manufacturing their steels. In a recent post on the Carter Cutlery Instagram page they showed a close up of the finish on some of their white steel blades and I noticed it there as well.
It was also really surprising how the carbon diffused into the mild steel cladding. These blades were only stock removal so I didn’t think there was going to be enough time for that to happen. But because of how thin these blades were during the HT it must have made it show the very little amount of carbon that did move. On the drop point blade just enough carbon moved to the cladding on both sides that it formed a very faint auto hamon. A similar hamon also showed up on the sheep’s foot blade but it was much more shallow and went away after enough grinding.
Both these blades are paper thin behind the edge and have an amazing edge flex, resisting breaking and bending. I think this makes them the perfect geometry to fully use the properties of white steel. They’re going to be amazing slicers if I had to go off of what they did to my fingers and hands during all the polishing.
I got some blue steel #2 laminate and homogenous white steel #2 back during the the holidays. So I’m really looking forward to seeing how the structure of blue steel compares to white when polished and etched the same way. I’ve already started to try out forging some of the homogeneous white steel. It’s a little stiff under the hammer but that might mostly be because I’m afraid of giving it too much heat and ruining it.
Any input on experience with forging white steel or knowledge of its structure would be awesome.questions and comments about my blades or process are always welcome too,
Kevin
Kevin
