- Oct 30, 2015
Last year I started working on a new sander frame and while I was at it decided to look around for a different motor option. Anyone that has seen my grinding style knows that I like to grind fast and hard. My previous motor was a 5 HP 3450 RPM. It was a hoss. But it was also very heavy and large and no VFD. Bought a 3 HP, 3 PH, 400 Hz, 220 V, water cooled, 24,000 RPM spindle motor and VFD for $242.00 delivered. Took me a while to design a suitable drive to allow the motor to operate in its full power range. I designed a tiny 1.125" diameter drive wheel. This would provide 7200 SFPM belt speed when motor is at 24,000 RPM. That was my target belt speed. It is great for doing fast initial removal with my bevel guide. The bevel guide puts heavy even pressure on the entire face of the belt and requires a good motor to be able to pull the belt under those heavy loads. Turns out that ceramic belts such as Cubitron really like these grind conditions.
I began initial testing this week. The VFD has an auto torque compensation setting and I adjusted it up. So far I am very impressed with the motor in all RPM ranges with ability to pull the belt under load. It is an absolute angry beast when running at high RPM and shreds the metal off without trouble.
The drive wheel failed due to design issues that can be overcome in future with better materials. So far the whole thing has cost $500.00 to have a 3 HP VFD motor that is far less than half the weight and about 1/4 the size of the standard 3 HP motor currently being used in many 2 x 72 machines.
See some development videos and bevel grinding.
