Willie71
Warren J. Krywko
- Feb 23, 2013
I posted this knife in the what’s going on in your shop thread, but this probably deserves its own thread.
The knife is 26c3, purchased from AKS, or it might have been a sample that Chuck sent me a while back. This was before covid. I was trying to increase hamon potential, so I put did two grain refinement cycles at 1450f, iirc. I did a partial grind, like a Sabre grind, clayed the blade, and heat treated at 1425f. I think I did a 10 min soak. I quenched in DT-48. I tempered to Rc64. I don’t remember the tempering temp, but I did start low, and walked up over 3 tempers. I checked Rc hardness on the tang, where I had no clay.
The blade was sanded to 1000grit, after grinding down to 0.005”, ffg. Easily 0.020” ground off at the thinnest point near the edge. Decarb should not be an issue after this much grinding. I have used this technique with W1, W2, 1095, hitachi white, hitachi blue, 1075, 1084, 1085, and now 26c3.
I did a couple hunters/camp knives in 1085, one done at 1460, one at 1450, several years ago, using the same grain refinement and u der austenitizing, which has worked in other hypereuctoid steels to bring out more activity.
the 1460 turned out like this:
The one at 1450 had a more washed out look. More like the 26c3.
I’m interested in anyone’s thoughts on why it goes washed out and cloudy, and not in a good hamon way, beyond the obvious over etch in the top knife.
Larrin
D
DevinT
