- Aug 27, 2004
Kingshoc - Black linen with a clip RH tip down carry w/lanyard DONE
Cotherion - Any color RH tip down carry w/ lanyard, Cobbler blade and Black and Red G10 DONE
DelrinFred- Cobbler blade, red linen Micarta, RH tip up low rider on liner lock DONE
Bruce Fried- Black and Tan G10 with a big lanyard hole. Cobbler Blade. tapped for RH Tip down only DONE
JAlexander- HAVE NOT HEARD FROM YOU AND DON'T KNOW WHAT YOU WANT SO I CAN BUILD IT
HiMalMtMan- HAVE NOT HEARD FROM YOU AND DON'T KNOW WHAT YOU WANT SO I CAN BUILD IT
WAITING ON BLADES You guys please be aware I'm going to just call it on your orders listed here remaining to be done. It is just something I can't do for you guys as no blades have been done and I am not sure but figure Koyote does not wish to do more so consider your orders cancelled as of this date which is August 5th of 2009. My apologies. Any questions contact me. I'm burned out on doing them so often anyways.
Teacher- (Koyote blade) Red Linen Micarta, liner lock
Thewoodpecker-Burgandy canvas liner lock RH tip up low-rider w/ a Koyote blade
Plowboy- Koyote blade, brown G10, low rider right hand tip down carry, liner lock
This one I am working on but it will still be a while. Dave has not cut out the blade shape for me yet which means its still a ways off.
Murdok72605- Frame lock right hand. Low rider right hand tip up, gold anodized 3V high flat grind blade sending his own steel.
consider thumb ramp on the blade spine w/ some traction grooves.
OK guys I have a lot going on right now in the way of some stuff I promised to get done for some folks before blade show that will keep me busy for the next however long it takes me to do the work and figure sometime around my birthday June 1st that I'll be moving full blown into and on top of this next run of BUSSTR folders for you guys listed above.
Inventory is done and here is what I have to go with this run.
In Micarta choices:
1) Black Canvas- enough for 3 folders none spoken for so far
2) Green Canvas- enough for 4 folders none spoken for
3) Burgundy Micarta looks like a B-Linen that I didn't know I had. Found it lurking in the top of the back of the drawer up there wedged in hidden from view. Anyway its enough for 2 folders none spoken for
4) Red Linen- enough for 2 folders both now spoken for
5) Teal Canvas- Enough for two folders
G10 choices are all smooth G10 not textured:
1) Blue G10 smooth, and enough for 4 folders none spoken for
2) Teal G10 smooth 1 folder none spoken for
3) Black and Tan G10 1 spoken for enough to do 1 more
4) Black and Red G10 enough for 4 folders none spoken for
5) Hunter Orange G10 none spoken for enough for 4 folders
G11 choices:
Lime Green G11. Found just enough for 1 BUSSTR also hidden in that top lip of the drawer.
Ok what I need from you guys is this.
Pick the type you want, frame lock, or liner lock. I have 4 right hand sets of the textured BUSSTR folders left for frame locks and thats all I have for this run. Frame locks have to use the Koyote blade.
Pick a scale material for your BUSSTR if you want the liner lock.
Lanyards are automatic now no need to mention that but I do need to know type of pocket clip and tip up or tip down carry.
I also need to know if you want a Cobbler blade or a Koyote blade model.
Again for your information the prices are: $135 each using Micarta handle scales with a Cobbler blade does not include a pocket clip in that price add $25 for a clip and tell me type and how. Koyote blade models are $200 each and Koyote blade frame locks are $300 each, $275 on the textured frame locks plain jane with no jeweling or blade finish and bead blasted slab finish. Pocket clips are included on that more expensive model.
Think about it and let me know. Thanks:thumbup:
STR
In Micarta choices:
G11 choices:
STR
