I made a couple 2x48 grinders and attached is a detailed build along. This is a fairly easy build that one can do with simple tools. It is largely just drilling and tapping holes.
A few key features of this grinder include:
-Nearly all parts are aluminum or painted steel to avoid rust
-The holes in the tables are blind (as I found that when I grinding on anything but a flat top, stuff gets in the way…for example when I am grinding slipjoint liners which have 3/32 pins holding them together, the pins will fall in a screw hole and hang the pieces up).
-It has a quick detach tool arm to make belt changes easier…also I often will rotate that tool arm 90 degrees to have a hand rest to perform free hand file work on liners.
-Because of the 1.5" toolbar, you are also able to utilize the tool arm slot (with a longer tool arm with different wheels attached) to accomodate 72" belts. For example, my surface grinder attachment is mounted on a longer tool arm and I can utilize this horizontal grinder to run it.
I came up with a parts list and the parts list along with this build along should get you there. If you ever are in doubt, just lay out the parts on your base and you will be able to figure it out. This is an easy build..just takes a bit of time.
This is a starting picture of all the components
To start, we will spot drill the motor shaft hole as well as the bolt holes.
We need to make clearance for the 56c motor. There are 2 ways to do this…if you have a mill, then you can simple mill out the area for the 56C motor face to inset into the bottom side of the base. If you do not have a mill, then simply drill right through the base with a 4.5” hole saw. In this build, I used a 4.5” hole saw to make the perimeter and then clear out the inside with a mill.
I then cleaned up all the rough edges of my pieces
