2X48 inch belt???
I got a used BALDOR 1/2 HP BELT GRINDER the belts I got with it says 2.5X50
but I cant seem to find any wondering if a 2X48 will work without moving things around. so I am asking for an old 2X48 to see if it will fit..I have some pics if anyone want to see (EMAIL) ... tnx
/ al
I don't have any but industrialabrasives.com will gladly make some up for you. It might be cheaper to modify your grinder to take 2 X 72. If you want to check if a 48 inch belt will work cut a strip of heavy paper and tape the ends together. This will at least let you knonw if it will fit over the wheels.
Jim A.
That's what I'd do, modify it. Get a bigger contact wheel in 2" diameter, or increase the size of the idler. Either way switch the contact wheel to 2".
That way you can grind on it without hitting the exposed surface not covered by the belt.
I don't think it matters on the idler of it's wider as you won't be grinding on that.
If it's a two wheel grinder, you might be able to get/make a spacer bar to space the idler back, to convert it to 2X72" belts.
made bad dumn stupid mistake. well not as bad as all that. but misread the notes inside the belt....2 1/2 X 60... oh well still looks like a good belt grinder and I hope to start on making sparks in the shop... will need a new contact wheel as this one is kind of messed up, and some belts all I have is kind of cource... tnx
/ al
Al
Don't throw away the old contact wheel. Just grind down past the bad spots using 60 grit paper glued to a board held against the wheel as it turns. Use a dust mask, safety glasses and old clothes, the black neoprene dust doesn't smell to good. when finished refacing the old wheel, get a strip of 2 inch wide natural rubber, usually obtainable from a local rubber company or call Hampton Rubber co in Hampton VA. sand these off at a 5 to one slope on the end and wrap it around the contact wheel stretching it slightly. Mark where the bevel on the other end needs to be and mark it with an ink pen. then bevel it to match the first bevel. Clean everything with acetone or denatured alcohol and glue up with contact cement. Once the cement sets turn on the grnder for a second or two to see if it is closed to balanced. If it doesn't jump around, then use the 60 grit board to grind it smooth then follow with a 100 or 120. Don't let the natural rubber grab the 60 grit smoothing board go easy. The fact the wheel is wider than the contact surface won't matter should be a quarter inch on each side.
Jim A.
