What’s up fellas. I’ve been a lurker here for a while but finally getting around to building my grinder so I figured I’d start a build thread to have a place where not only I can ask you guys questions, but anyone else in my boat can also gather info and use any thing I may be able to provide.
Atm life is extremely hectic, so this will probably get drawn out longer than I would hope, but it is what it is. I’ll get it finished when I can.
To start with, Stacy was very generous and hooked my up with a 1hp 3phase 56c motor that I’ll be using. He’s been very helpful in general in my short time here lurking and trying to gather info. Thanks Stacy!
I started with .dxf files from Kevin’s build thread, and planned on just building the same grinder he built, but my metal man uses a laser to cut material. And apparently he couldn’t cut such small holes in 1/2” thick stock, with the laser. So I began to modify them to be more of a weld together design and be built with 1/4” thick material instead. If everything works out correctly, and kevin doesn’t mind, I’ll gladly post the .dxf files here as well so anyone else can use them. I don’t wanna post them until i know it works bc I don’t want anyone jumping the gun and having a bunch of parts cut that won’t work. Haha
So far, I’ve got the main frame tacked together and just recieved my wheel kit from origin blade maker and tensioner pulley hinge from Amazon.
Next order of business is to start tapping holes and figuring out how to get all the wheels on same plane so it’ll track properly, I guess. Also need to figure out what size bolts and bushings/spacers for axles.
(also, I have a few pics ready to share. Thought I’d just post them here. But can’t figure out how to do it from my phone?)
