SolarStorm50
- Dec 10, 2020
Misting System for under $13CAD (about 42 cents USD). How I keep heat treated blades cool while doing finish grinding
BTW, $13CAD is $9.16USD.
I thought of stuff like that, but I have moved it around quite a bit and am finding the ability to clamp it in different positions valuable. My grinder tilts to horizontal as well and need different points. I have even used a tripod to clamp the mister to when I was in an awkward position. Of course having a good selection of clamps (which you can never have too many of) always helps.I gotta get off my butt and get my compressor going and the mister set up! My grinder table has a stainless cover on it, so I will probably add some low sides and direct it back down to the spark collection tank.
If you have an aluminum grinder, get some double sided vhb tape and tape a piece of mild steel to the bottom of the mister unit and double side tape a magnet to the grinder frame? Or epoxy? I plan to vhb tape a magnet to the mister unit and then stick to the Ameribrade with the magnet so it's re positionable.
do what works. I thought of permanent mounts, but got used the clamping. Its quick easy and movable. with an AL grinder, the magnets werent and option. One problem with the magnets might be the dust they will collect and it will "magnetize" the steel (I think) and have the dust cling to the steel on your grinder.Ah, ok. Would velcro be an option? Velcro pads/strips?
I figure if I do the magnet on the mister piece itself, my grinder and tool arms are steel, so I think I should be good. Wife is stuck late at work training, so maybe I will get to play in the garage, or set up the compressor in the house and torment the dog with it. Blow off all his winter coat and blow his hair back at him!
Sorry, working a 16 hr shift with only a few hours sleep...kinda loopy!
I agree, foot pedal is amazing and saves a lot of air and waterthe mister systems are really good - been using one for a couple yrs now. Do you have a footswitch to control water flow? It really cuts down on wasted water. Something like this: https://a.co/d/4fqWhQU
