- Feb 12, 2019
Note: this is my first post. I hope I get the photo in right.
https://www.flickr.com/gp/162221671@N04/P2Hut7
The only thing you need to check is if it's TEFC or not. I'm not sure if "all 56C frames are TEFC or not. "IF" you're getting it for almost free, then using it until it does go bad from metal dust won't hurt anything, but another 56C motor will bolt right up for <$200 new.
TEFC cooling is nice to have, but for the short length times we run a grinder a TE is sufficient. There is usually an internal thermal breaker that will shutdown the motor if overheated.
If you really worry about it, put a small pancake fan ( surplus computer fan) about an inch behind the motor. That will actually be better than a TEFC motor, as the fan on TEFC is only efficient at near full speed. As you lower the RPMs, the cooling drops by the square of the speed drop - at half speed, it is only 1/4 efficient at cooling.
BTW, TEFC fans need to be blown out and vacuum regularly. The dust and steel from running a grinder can clog them badly.
I looked into using a 15 hp gas engine to run a grinder. For the size, weight, torque and most of all expense of operation, electric is the way to go!
Lol! I can only think of how fast I would ruin knives...But think of how fast you would be able to profile blade blanks. I've seen some used car engines for only $100.
