- Jun 20, 2007
I am putting together all the componets for my KMG clone grinder build. Here is the question that has poped up in my mind and since I have never had any experince here, I have to ask these questions.
The motor I am looking at is a 2 HP TEFC 1 Phase Electric Motor 56HZ 7/8, Speed/RPM: 1725
1. Am I correct in my understanding that you have to have the 3 step pulleys on both motor and drive shaft for the grinder, and they are tuned in reverse of each other (like on my drill press) to be able to obtain a variable speed setup?
2. Will I need to run a 4" 3" 2" step on both motor and drive shaft or will one of them need to be different size on the steps?
3. Does someone have a scematic for the various speeds that can be attained! Or is there a formula for figureing it out using a 4" 3" 2" step pulley on both the motor and drive shaft
Any light you can shed by some of you that are running the step pulley set up would be appreciated!!!!!
