- Dec 15, 2009
I'm planning my press build with the help of Baton's book, Eric and the Count, plus a few others (and all of you of course -- thanks to all!). I am sourcing parts based on Baton's build and Eric's design.. and I've got the motor and plan on getting the cylinder next, so I can plan the frame height accordingly.
Batson recommends a 5" x8" 2500psi cylinder with a 1 3/4" rod from Grainger, which is $558 US + shipping.
http://www.grainger.com/Grainger/ww...ae-8208&op=search&Ntt=sae-8208&N=0&sst=subset
Whereas Northern has a 2" shaft 3000psi cylinder for MUCH cheaper at $289.99 +ship.
http://www.northerntool.com/shop/tools/product_23518_23518
I plan on using the same pump or one with the same specifications as Batson used, which is 5.5 GPM @ 2500psi w/ 2 HP (I have the 2HP motor already). So my build will be 2500 PSI.
What I am unclear on is although the cheaper (stronger 2" rod) cylinder has a max pressure of 3000 psi, will it run as effectively (the same force) at 2500 psi, or do I need to shell out and get the more expensive one?
Merry Xmas all
Merry Xmas all
