- May 18, 2017
New addition. Somewhat rushed, and made to someone else's specs (hence the size, shape, texture and notch cut into the aft portion of the blade). They wanted the finish and texture to have sort of a home-made, post-apocalyptic feel, so this is what I came up with.
Buffalo horn handle, patinated carbon steel blade (patinated in weak acid to protect against rust), large nickel-silver pins. I had to fudge it a little. It's a large blade, and all I had to bevel it was an angle grinder. More to come!
Finished product
Finished product, after patination
Handle after applying a thin coat of West System's 105
Fitting up the scales, before patinating the blade
Blade after adding texture, drilling handle, heat treating and semi-polishing the blade
Freshly beveled blade
Finished product
