With a 2-pole motor, I'd normally recommend a Sensorless Vector drive, particularly if you use low speeds for sharpening. These will drive the motor smoothly at speeds well below the 10 Hz or thereabouts that tends to be the comfortable minimum for V/Hz drives. The KBDA-29 seems to be a Sensorless Vector drive.
With the KBAC, I'd be more inclined to use a 4-pole motor and run 10 Hz to 120 Hz for a 300-3600 RPM speed range.
With the SV drive (KBDA?), you should be able to run the 2-pole motor between 2 Hz and 60 Hz for a 72-3600 RPM speed range.
It is worth noting the motor is not Inverter Rated (however, it has class F insulation, so will run from a VFD), so this effectively means that it will need derating at low speeds, This might sound like a potential issue, but tends not to be in "our" application: we tend to use light pressure at low speed and that intermittently, so the derate usually happens unconsciously.
