- Jul 31, 2015
Anyone have a recipe for 3v using dry ice for sub zero quench? Is dry ice even advantageous for this steel?
Phillip, didn't the guys who developed the low temper regimen discover that cold/cryo was even more important than with the high temp method?Yes it is. We have been using dry/ice sub zero as part of 3v heat treat with low temper for a long time. From my testing I prefer it to high temper. Butcher_block was the one who first mentioned it around here that I remember.
in the playing around that i have done (only cryo not dry ice) it can be a great benefit to higher alloy steels and steels that are known to be higher RA holders. the reason i had played around with 3v is due to the HT data is all worked around size change for tool and die work not knife work. the thought being that in knives that didnt matter as long as the RA was cleaned up and the steel matrix stabilized. i was already using cryo on cpm154 back then and after much reading and talking to some big brains in steel science it was confirmed that cryo will clean up the RA withought needing the high temp temper. as for how much difference with or withought cryo a knife maker asked me for a HT to use on cpm154 later he said he didnt want to fool with it for the few blades in SS he was doing so i HTed them. when he got them back he wass shocked at how much difference in grinding and sharpening his HT and my HT had
What do you mean dimensional stability isn't as good using cryo? Do you mean stability between pre-heat treat and post? Because cryo treated pieces should provide the most dimensional stability of a finished part, no?
Willie any detriments to using high temper and dry ice? I like the idea of using high temper as I can flirt with the temper more when I grind as I like to grind post heat treat?
When I did plate quench and high temper, the knives came out straight was an arrow. When I had straight blades going into cryo, they come out a bit warped. The steel moves more than when using high temper.
