Hey guys, looking for some assistance on a **** up ive made on my first knife handle.
so i clamped the scales to the knife and drilled the rear hole through the knife and scales then put a pin through that hole while i drilled the front hole,
i must have been off axis when drilling the front hole tho, as when it came to glue up with the rear pin in, the front scale holes wouldnt line up with the knife hole,( i used a hand drill
) so i had to improviose on the spot (covered in epoxy lol) and stick a 4mm pin through instead of the 4.5mm that i had drilled for, as a result i now have a slight gap around the front pin.
i can think of two solutions and was wondering what your thoughts were on them or if they would even work.
1 i could fill the gap with sawdust and ca glue it, or
2 peen the brass pin enough so it fills the gap?.....this is the prefered method but im not sure if it will work???
does any one have any experience with this kind of **** up, or do you have any other solutions.
bear in mind this is my first knife and you do learn from your mistakes lol
thanks in advance
Thomas Nutter.
thanks in advance
Thomas Nutter.
