Not that I know of, but I wouldn't be surprised if they were actually the same. And if they are different, the difference is probably so small you wouldn't notice it with normal use.Is there a way to tell the difference between these two?
400SS or Aus8?
Are there any known cases of 400SS being 440B, or would that have been considered good enough to call out by name?AUS8 is a specific composition as it is a steel made by a single company, Aichi Steel in Japan
"400SS" is a non-specific designation. It could be any one of a half dozen different of alloys with different properties. And made by dozens of companies. Among the possible alloys are 410, 420, 420HC, 425, 440A, 440B, 440C. They all fall under the category of "400 series stainless steel"
Without a more specific description, the most likely guess would be that it was 420HC or 440A or pretty close thereto.
(If it had been 440C, they would have said so.)
AUS8 gets short shrift these days because too many companies cheaped out and ran it soft. For instance Ontario's spec for AUS8 was a 56HRC. But it works well if run at a hardness of 59 or better as Cold Steel runs it.
AUS8 has a higher carbon content and performs better than either 420HC or 440A. IMO the difference is noticeable in use.
The performance of 440B is significantly above that of 420HC and 440A, both of which are covered by the moniker "400 series."Are there any known cases of 400SS being 440B, or would that have been considered good enough to call out by name?
Thanks Frank. Guessing that if you're gonna go thru the extra effort, might as well just use 440C? Is that why 440B isn't/wasn't very common?The performance of 440B is significantly above that of 420HC and 440A, both of which are covered by the moniker "400 series."
I've never seen a case in which a knife company was using 440B and didn't say so. 440B is less commonly used in industry. Obtaining and processing it requires extra effort compared to 420HC or 440A. If it were being used, I'd expect the user to make it known.
Still find it odd though, if AUS8 was a big step up from the 400SS they were using, that they didn't promote the improvement. Unless they did, but in a form other than their catalog. Oh well, at this point we'll prolly never know for sure.
