Is it just me or are these steels the same? I'm trying to figure out because I'm eyeing a knife that is listed as 440c on some sites and n690 co on other sites.
They're not the same steel. They are similar in terms of C and Cr content, but 440C has no Cobalt, unlike N690Co. I'm quessing you were looking at a "red class" Benchmade knife of some sort.![]()
What would you consider a hard use steel so I know where you are coming from?fox unfortunately uses n690, the karambit is made with N690co, Fox Cutlery and Lion Steel use it very often, unfortunately here in Italythe steel is very fashy also because of the Extrema Ratio thing,unfortunately it's not a great or even good steel,it's just not bad
ER has a great marketing strategy, unfortunately many tests prove that N90co is not a hard use steel not only being stainless and not cabon but because i'ts "good" only for small knives and not for hard use ones.
I've seen too many test of n690 steeled knives fail and have personally and with some italian forumites tested to see how they performed.
I'd like to give a personal suggestions to many US forumites, if you like the design ok, buy them but if you plan to use thembuy a real hard use knife, learned this also here on BF
cheers from Italy
Maxx
Nope, 2 different steels, see for yourself 440C vs. N690 composition comparison.Is it just me or are these steels the same? I'm trying to figure out because I'm eyeing a knife that is listed as 440c on some sites and n690 co on other sites.
for self defense it's OK, any steel even 440A would be good, I was talking about n690co for hard use military knives or hard use knvives NOT only meant as fighters
cheers
Max
N690 is not the same as 440C. The compositions are different. The performance is different. In my side-by-side comparisons cutting manila rope N690 held an edge better than 440C. The edge retention performance of N690 was similar to that of 154CM and VG10. In my opinion N690 takes a finer edge than 440C, though I can't measure the difference.
Neither 440C nor N690 is a suitable alloy for a chopper. Either would be excellent for a cutter.
Lion Steel made some knives for fox, one being a licensed copy of the NEXUS Caio (some here know the NEXUS knives) made of n690, it broke right after some wood choppind and batoning, first the edge CHIPPED then with little trouble ine of our testers managed to break it, no abuse, just hard use as could occur in a survival situation
N690 is an EXCELLENT user steel, but I would not use either it or 440C for a large chopper-type blade.
That is one of the main reasons I decided to sell my Spyderco Hossom Forager before I used it even once. Thing I don't understand is why Jerry Hossom, who one would assume is quite knowledgeable about steel, would either recommend or simply abide by the use of this steel in his large chopping knives. I have read reports of Spyderco Hossom blades chipping out with hard chopping.
