440C Material property
Material Property Data
Stainless Steel 440 C
Specifications
Related Tradenames and Metal Names
Chemistry Data
Welding, Machining/ General Data
Physical Data
Mechanical Data
Links to Related Data
Specifications
The following specifications cover Stainless Steel 440 C
AISI 440C
AMS 5618
AMS 5630
AMS 5880
ASTM A276
ASTM A314
ASTM A473 (Forging - Open Die)
ASTM A493
ASTM A580
DIN 1.4125
QQ S763
UNS S44004
Property Results
No Related Metal names.
Chemistry Data : [top]
Carbon 0.95 - 1.2
Chromium 16 - 18
Iron Balance
Manganese 1 max
Molybdenum 0.75 max
Phosphorus 0.04 max
Silicon 1 max
Sulphur 0.03 max
Principal Design Features This is a high carbon martensitic stainless with moderate corrosion resistance good strength and the ability to obtain and keep excellent hardness (Rc 60) and wear resistance.
Applications Ball bearings and races, gage blocks, molds and dies, cutlery, valve components, knives and measuring instruments.
Machinability Best machined in the annealed condition. Tough, stringy chips can be best handled by the use of chip breakers. Carbide or ceramic tooling is recommended.
Welding This alloy is not commonly welded due to its tendency to air harden. If it must be welded, preheat to 500 F (260 C) and post weld treat at 1350-1400 F (732-760 C) for 6 hours followed by a slow furnace cooling to avoid cracking. Use similar filler metal and high heat inputs during operations.
Hot Working Pre-heat to 1400 F (760 C), then bring slowly up to 1900-2200 F (1038-1204 C)before proceeding. Do not work this material below 1700 F (927 C). Cool material slowly after working and once at room temperature, anneal fully.
Cold Working This alloy is considered only slightly cold workable by common practices.
Annealing 1550-1600 F (843-871 C), followed by very slow furnace cooling.
Tempering For maximum properties, soak at 300 F (148 C). Maximum obtainable hardness is RC 60.
Hardening Bring the material slowly up to 1400 F (760 C), then on to a soak temperature of 1850 F (1010 C), air or oil cool.
Physical Data : [top]
Density (lb / cu. in.) 0.275
Specific Gravity 7.63
Specific Heat (Btu/lb/Deg F - [32-212 Deg F]) 0.11
Electrical Resistivity (microhm-cm (at 68 Deg F)) 360
Melting Point (Deg F) 2700
Modulus of Elasticity Tension 29
Mechanical Data : [top]
There is no Mechnical data available for this grade.
[top]
Nickel - www.nidi.org
Copper - www.copper.org
Titanium - www.titanium.org
Steel Lynx - www.mlc.lib.mi.us/~stewarca/steelynx.html
Nice first post Fireblade Systems, that seems like a helpful reference.
Welcome to the forums.
