Someone in the BG-42 vs S30v (I think it was Dan Gray) mentioned that 154cm holds a better edge than 440c but 440c is tougher. To what extent is this true? I ask because I am about to make several knives that are bigger than what I usually make (5"-7" blades) in 5/32" stock. For most small knives, like the ones I make, toughness isn't such an issue but I'm worried that my old reliable might not do the trick for some bigger, heavier blades (although I know they're not THAT big or heavy compared to a lot of the stuff you guys make). Is the difference in toughness going to be a problem with these blades? Will tip and edge geometry make up for the difference?
Thanks,
- Chris
Thanks,
- Chris
