6 weave vs. 4 weave
I recently saw a thread that referred to different types of G10. Apparently the Military uses 6 weave G10 as opposed to supposedly inferior 4 weave. Could someone clarify this for me? Does this refer to the number of threads per cm in the laminated material or what? I hope this hasn't been covered a hundred times before. I tried searching but couldn't find an answer. Thanks,
Paul
I'd also like to know where the six-weave are. When I got my Military I took out my 10x magnifying glass and tried to count the weaves. Are they so small and tight that I failed to find any?
I may be wrong(wouldn't be the first time) but I believe it refers to thickness and yield strength. It's not so much that one is better than the other just thicker and therefore stronger.
Sorta like 6 bullet proof vests instead of 4.
Compare to Benchmade (4 weave but then they have titanium liners) the Military has 6 weave and 1 SS nested liner. Stronger? I think so. Survey says....
God bless!
Romans 10:9-10
"Military" Fans Unite!!
Paul - 6 layers of glass fibre compressed into the same thickness as 4 layers. One is not necessarily better. Depends on the needs. On the linerlocks that we make, I opted for the overall thinness of the model. This meant that we needed stronger scales if we to use only one liner, and still maintain lock stgrength. The money saved in liners is more than spent on the extra meterial and processing. It depends on your needs. 4 layers is plenty strong enough for a lockback, or a linerlock with double liners.
You will find others using thicker and thinner layers as time goes on. We're earning more and more about this stuff. With the RL we're starting all over again. What breaks first, strengthen it, now what breaks, change the heat treat, now....
I don't know how many layers can be compressed into what thickness. The need to learn that has not come up yet. What other new materials will we discover that will again change everything. How about a laminate with G10 and carbon fibre...hmmm. Hope this helps.
sal
Thanks for the clarification Sal and William! I was wondering about the combination of carbon fiber and G10. It seems that most people dislike c.f. because it is slippery but it is supposed to be stronger than G10. Could they be molded into a solid composite sheet? Maybe this would pose no advantage. Has anybody done anything like this?
All good answers should lead to more questions.
Paul
