I'm not Cliff, but I've been following his work, as well as posted discussions with Alvin Johnson, Phil Wilson and a couple of other knife makers who try for higher hardness. Phils work with the listed stainless steels at >60 is interesting and promising, although I cant afford his work. A2 at ~64 seems a good bet, but I dont know anyone who's tried it. It looks like the tempering temperature is more important than the actual hardness. David Boye recommends 62.5 Rc for A2 in his book. With a subzero quench he says 1-2 more hardness points can be gained without a loss of toughness. The tempering temperature agrees with the toughness peaks from Cliff's site, which I believe come from ASM. Alvin seems to like M2 at the second hardness peak of 1000 degree temper for a hardness of ~65, although he says you have to be careful. Check with Phil for D2 at 61 - 62 Rc. I can attest that 1095, quenched, frozen to -5, and double tempered at 325 F is a lot tougher than I would have expected. Alvin gets a hardness of 66 Rc. I dont know how hard mine was, but the kiridashi I made took a piece out of my garage floor with a slight ding in the tip, with and included angle of ~20 on a chisel ground tip. It would also cut steel wire (for tying reinforcing steel) at that angle without gross damage, just dulled. I have for about 3 years now believed that sharpening has much more to do with geometry than steel. The knife that took the longest for me to sharpen was a Cold Steel Safekeeper in AUS 8. Reprofiling took nearly 2.5 hours on a water cooled 12" stone turning at about 100 rpm. I'm interested to see how a Cold Steel Scalper type knife in 1095 at that hardness would work. I have some left and may give it a try if I can figure out how to HT it with my current equipment, or pay for it if its not over $20. I also have a Nicholson file blade that needs to be given the same treatment, ~ 3" long.
