- Aug 31, 2012
So, I got gifted this 7' crosscut saw from the next-door neighbor of our jobsite a few weeks back.
It was a bit rusty but I thought it would be a good candidate for my first electrolysis rust removal project. I figure this will probably lead me to learning how to sharpen it too. Here is what it looked like when I got it.
After a little internet search for 'electrolysis rust removal', reading a few write-ups and watching a couple videos I figured I was all set. This electrolysis thing looked simple enough. Just add 1 tablespoon of sodium carbonate (i.e. washing soda) to each gallon of water, hook up some rebar (anode) to the positive lead and the saw (cathode) to the negative lead of the battery charger, submerse the whole shebang in the electrolytic solution (except extend the rebar out of the solution so the positive lead of your charger doesn't corrode away to nothing), plug in the battery charger and watch the bubbles form and the rust fall off while practicing all the safety precautions. How hard could that be, right?
Well, Saturday morning I spent a couple hours building the box that would be lined with plastic and act as the tub for the saw to bathe in. It took a couple hours to get it all set up and ready to go.
I plugged it in and nothing happened. Pushed some buttons on the battery charger and still nothing.
I figured the connection to the saw was not a good one so I scrapped the clips back and forth on the saw and started to notice little sparks and lots of bubbles forming and the battery charger's charging lights came on. The problem was that the bubbles were only forming right at the negative lead clip and not down the whole length of the saw. Then the charger would shut off every couple minutes or so. I took a little sandpaper to the spot on the saw that I was connecting to in an attempt to get a very good connection. At that point the battery charger would not charge at all and was acting like it was shorting out. After checking and rechecking the set up to make sure the saw was not shorting out to the rebar and that everything was hooked up right and that I used the right ratio of washing soda to water I went and saw a movie.
Eventually, I came to the conclusion that it was something in the battery charger that was switching it off whenever the negative lead even touched the solution while the positive was hooked up to the rebar. I decided to borrow a different battery charger. This borrowed one being a Napa brand "automatic" battery charger. I hooked it up and nothing happened again. Frustrating to say the least. This is not rocket science!
I started draining my 30 gallons of solution with a syphon thinking that somehow my solution was contaminated or something was wrong with it. Then I got the idea to hook up my truck battery. Truck batteries don't care what is happening when anything is hooked up to them. So, I tested it on a carpenter's hatchet head in a 5 gallon bucket before hooking the saw up to it. That hatchet bubbled like crazy and it was time to hook up the saw to the truck.
The battery charger got hooked up to the truck battery too after a little while. It was fine with charging the battery even though the battery was connected to the anode and cathode in the solution. Bubbles were forming like crazy and I was quickly able to disconnect the handle parts so they could be wired up too.
After about 6 hours of electrolysis it was getting dark on Sunday evening and the truck battery was about out of juice even though the battery charger was hooked up to it on the 2 amp setting. Since I need my truck on Monday morning it was time to see what kind of progress was made. Most of the red rust was removed from the handle parts and some red paint was exposed.
I'm thinking its easier to finish them off in a vinegar bath rather than wire them back up for more electrolysis so thats what I did.
The saw will probably get another treatment of electrolysis next weekend. I will flip it over and spin it around to get more of the red rust off that was shadowed from the rebar by the stands that I made to hold the saw away from the rebar. This is what it looks like now.
The electrolysis exposed a stamp that reads "E839" on each end of the saw on opposite sides. I tried to photograph it but it wasn't showing up very well. Maybe I can get a better shot of it later? No visible etching has shown up yet. Maybe I will hit it lightly with a scotch bright pad after the next round of electrolysis?
I have come to the conclusion that if you are going to do this electrolysis thing don't use an "automatic" battery charger. I will be looking for one that sparks if I touch the + and - leads together. Older ones that are not so "automatic" are the way to go IMHO.
