8" Scotchbrite Buffer Wheels
Can anyone point me to a source?
Regards, Dave
WinDancer@OlyWa.net
www.olywa.net/windancer/webknives.htm
Thanks for the info. Based on another topic I tried taking apart one of the scotchbrite setups for a drill, and installed that with washers and nut on my buffer. It works perfectly! This is the setup I was looking for to remove light sharpening scratches.
I will also start keeping my old hand-pads for this purpose.
Again, thank for the tips!
[This message has been edited by WinDancer (edited 06 July 1999).]
If you can't find the exact wheels that you need you might try purchasing some #7446 rectangular hand finishing pads and stick them on the shaft of your buffer. These make a good wheel for putting a fine satin finsh on blades. I use the pads in the shop all of the time and save the "worn out " ones to use on the buffer. I just punch a hole in the center of the pad and put them on the shaft between two nuts and washers and start running. They wear into a wheel shape quickly so there is no need for trimming.
george
www.tichbourneknives.com
sales@tichbourneknives.com
almost any machinist tool supply catalog will have these listed....and they have the best prices tool....msc in new york.... rutland tool in calif....(msc stands for manhattan supply co. i think)
imperial tool is the best place I have found to get the unitized wheels they usualy have a good stock and are resonably $ and shipping is fast.
