80mm Manix question...
tatsu
Basic Member
I recently received an 80 mm Manix. I noticed there is a bit of blade play. Upon further inspection, I noticed that there is only one tiny p/b washer. The other side of the blade seems to be rubbing the steel liner. Is this right, or should there be washers on both sides?
Thank you,
Jason
Well, if nobody else replies, I'll let you know when I get mine in a few days, but at the moment I don't have one to check but I would think it should have one on each side.:confused:
I don't own a Manix 80mm, but I would expect there to be washers on both sides. Call Spyderco, they can give you a better answer than I can. Probably just a mistake.
Got mine yesterday, and there is a TINY phos. bronze washer on each side. Hope that helps.
