I decided to take some pics while messing around today. I should the mini hatchet here http://www.bladeforums.com/forums/s...t-Chopping-Down-A-Tree?highlight=mini+hatchet And how it's quite a handy piece if kit size restrictions limit you. It outperforms some "choppers" with an expedient handle, is about 5/8 inch thick. It combines with the blade IMHO for splitting, keeping a long knife of less weight that is quicker in hand and often of longer reach then similar weighing more thick knives, and it chops if necessary- with great geometry that ejects the chips.
Tram 14 inch bolo: reach without too high of weight penalty. Very quick. Mechanical advantage on splitting wood isn't high obviously with the thin stock.
Sometimes it needs a little help in my opinion. You have to drive a thin blade like that a far ways down for the wood to pry away far enough to insert a fabricated wedge. The 7ozMHB can help, both using a baton.
The Mini on it's own with a baton
Combo: the long blade is cutting through splinters that are holding the two pieces of wood together, the mini at 5/8 started a nice split.
The mini and Vector's Little Chill knife
The Mini and the Large Kabar Heavy Bowie
That's what happens when you combine a .240 knife with the Mini
Using scrap lumber with a quick fab wedge for more Mechanical Advantage.
Mechanical Advange kicks butt!!!! Especially when you didn't have to carry a weighty piece of steel to provide it!
5/8 is quite effective on seasoned wood.
