Hello again! I jsut got my 50 grit ceramic belts and the A-2 from Mcmaster-Carr today. I ground out the blade of my uncle's skinning knife. right now, it kinda looks like a buck vanguard with a LOT of belly. Blade is about 4" with a half inch choil or cut out thingy, about 7.75" total. Now I just have to shape out the handle, drill it and get it heat treated! The grinding went incredibly well tonight. I got the tracking problem solved. Put a bunch of masking tape of the big driving wheel and now that belt stays where it should be! The steel is 1/8" thick, so it has a nice, thin shallow flatish grind to it. I can't believe how smooth the finish is, even after I used a 50 belt! The 0-1 got very rough with the 50, but the A-2 is still pretty smooth. I have the feeling I will like to work with this stuff. I think I might change the handle up a little. I think I will forget the bolster and just do a full stag handle. Any opinions? should I keep the bolster in? It will have an integral guard, so that won't be a problem. I also might get rid of the second finger bump, too, so the handle will be wider and less sanding and grinding of the stag handle. the handle would be kinda like Mr. Blackwood/Dr. Lathe's large hunter, but with less of a bump at the end. On second thought, that bolster looks good on his!
http://www.geocities.com/Eureka/Meeting/5520/page2.HTML
The dimesions are like this one and I like the look of the full stag handle! the blade itself looks kinda like the Buck Vanguard.
Decisions, decisions, decisions! I will try to get the knife scanned this Weds at work before it goes out for heat treating, probably Mr. Bos.
